Apr 13, 2024 19:51:02 GMT
Thought I’d stick a thread up about the fiat panda 100hp I’ve just picked up. Recently had my first child so need something a bit more child friendly as the Land Rover 90 isn’t. Found this locally relatively low mileage for the age of it with part service history. Plans are to clean it up as the paint work isn’t the best and the interior stinks of wet dog. Once it’s had a deep clean it needs a service and some general maintenance then I’ll do some subtle mods (oem+). thanks for looking.
1988 Landrover Ninety
Apr 13, 2024 21:08:36 GMT
Pretty cool, always admired these, although I currently have an Abarth Grande Punto Esseesse with pretty much the same paint colour (mine's Scorpion Black). I've heard of folk putting the AGP engine (155/180bhp as standard, and easily tweakable for much more)/gearbox in these, or general Abarth type mods.
Yeah, the Tjet swap seems the only real option for an engine swap with these. It needs a suspension/ beam refresh first though, currently waiting for I'm axles to release their new rear beam for the 100hp as you currently can’t buy them new. And quite a few Abarth 500 items fit on these
Apr 14, 2024 21:28:41 GMT
Being based on presumably the same 1368cc block as the Abarths, isn't it simply a case of swapping the relevant T-Jet or even Multiair parts onto it?
Being based on presumably the same 1368cc block as the Abarths, isn't it simply a case of swapping the relevant T-Jet or even Multiair parts onto it? I thought the same but from what I’ve read the 100hp engine can only take around 140bhp before the gearbox and internals start to throw a wobbly so it’s cheaper to just swap the engine rather then turbo the existing unit.
So I’ve fitted some wind deflectors as I always drive around with the window down and I’m currently going through the stages of clay barring, cutting, polishing and waxing every panel. Obligatory snow foam picture and 2 bucket wash front passenger wing before and after Quite a few marks on the bonnet managed to get most of it out. Before and after the paints never going to be perfect quite a few stonechips but I’m happy with the improvement still got a load of panels to do, which I’ll hopefully do today and I want to restore all the plastics aswell. thanks for looking.
Last Edit: Apr 15, 2024 8:37:24 GMT by JoshB68
Davey
Resident Tyre Nerd.
Apr 16, 2024 15:25:48 GMT
Love these, great job on the paintwork.
Apr 23, 2024 18:55:12 GMT
Had a rain free day today so done some more bits and bobs on the panda. First up all the black plastics are faded and now a lovely shade of grey. So after doing some research gtechniq c4 seems to be the best trim restorer. So cleaned all the plastics with some apc and gave them a good scrub and then wiped down with panel wipe, the g4 was easy to apply using the applicator and then buffed with a micro fibre cloth. I’m happy with the results and if they stay like this for the claimed 2 years it’s definitely worth the price. Trims before: and after: Also replaced the cabin filter, looks like the old ones been in a while replaced the air filter aswell. All the lower bolts in the air filter had rusted to nothing so replaced all of them with some nice stainless bolts. and while the air box was off I changed the plugs. next up will be an oil/ oil filter change and a new water pump and timing belt when I get a chance to fit them. thanks for looking
Another little update, the old fog lights have seen better days, the inner chrome has started to peel off the reflectors and gone yellow. so I purchased new fog lights, bulbs and some stainless steel hardware. I’ve wrapped the new fogs with some yellow tinting wrap. First time wrapping anything and it’s harder then it looks took me about 3 attempts on the first fog. Reading up on changing the fogs everyone says it’s a pig of a job to replace them as the old fixings have normally rusted to nothing and need drilling out. Think I got lucky as every screw came out easily. Thanks for looking.
May 13, 2024 20:44:01 GMT
2 lessons learned today: 1. Don’t trust eurocarparts reg checker, ordered an oil filter and it’s miles to big, so ordered another from Halfords which was correct. The oil filter is tiny on this. 2.most Allen key sets only go upto 10mm the gearbox fill hole is a 12mm.
The gearbox only had a litre of oil in it, supposed to have 1.7l and I could only find 75w85 oil online. But now it’s got the correct amount in so hopefully will make the gearbox smoother.
Hopefully going to jack it up this week and strip the arch liners off, degrease/clean underneath then coat everything with a healthy amount of dinitrol and BH dynax.
May 14, 2024 16:36:26 GMT
My Multipla also required a 12mm allen for the gearbox drain and fill plugs, with the added joy of the drain being so awkwardly positioned that you had to shorten the said allen key's head to gain access!
May 14, 2024 18:52:44 GMT
My Multipla also required a 12mm allen for the gearbox drain and fill plugs, with the added joy of the drain being so awkwardly positioned that you had to shorten the said allen key's head to gain access! The panda luckily wasnt bad for access and the fill was 12mm but the drain was 8mm, noticing loads of weird quirks like this while working on it
