Morning All,
Got my B4 Passat to get rid of. It's got the AAZ engine, so it's not the fastest. I've been doing some pretty heavy miles in it recently and its been averaging about 49-50 mpg which is pretty good!
Not even close to a perfect car. Some rust on the left front. Just surface, but will need a sanding down and painting to prevent it getting any worse. Front right arch is fairly new, not painted. Both rear arches have been done recently, previous owner graphed rear arches from an A4. Also had new wheel bearings on the rear right and left.
The front suspension needs attention. Possibly a re-alignment, the lowered springs aren't sitting on the rubber quite right and therefore spin when you turn the steering. I have new rubber cups for that. I also have a set of original VW wheels with trims with fairly new tyres, and a pair of roof rails that fit this model.
Its been sat on the drive for a while, it has a small crack at the very top of the windscreen. The rear windows are supposed to be electric, they do not work at all. Front left window does work, but occasionally decides it doesn't work. I replaced the regulator on the drivers side and occasionally it will roll itself down. Likely that I haven't got the plugs on properly.
I'm more than happy to negotiate on price and I am happy to sell the car without the wheels with a reduction on price. I'd prefer it went to a forum member and was looked after.
MOT until March
MOT until March
