Jan 27, 2024 14:07:15 GMT
Hello. This is my first post here . I am looking for some help with recommendations for garages preferably in the south east but I am willing to go anywhere in the UK. I have a Volvo 240 that I would like to engine swap for a turbo redblock . If anyone has had this done I would love to get an idea of the cost . I have the turbo engine already . Just need to find the right place to do the work ( and save up!) Thankyou .
mylittletony
Club RR Member Number: 84
I don't know of any garages in particular, but if you can work an engine crane and a socket set, they're about as straight-forward as it goes.
A garage will charge you upwards of £50ph to do it and you're looking at a decent amount of time
What year 240 is it? This can affect how easy things like the wiring are
Jan 29, 2024 10:04:05 GMT
Hi, it’s an 88 but unfortunately not the lh2.4 edition ! I have somewhere to get a new harness and change it to lh2.4 first . Thanks for your advice . I was hoping to get it done at a garage as the car is my daily drive . Once I have upgraded the engine loom ( and flywheel I think) I may have the confidence to attempt the swap! Many thanks .
mylittletony
Jan 29, 2024 10:25:35 GMT
If you're going to change the flywheel and wiring, you'll have done the hard yards. The exhaust downpipe and intercooler are the pretty much the only remaining 'hard' bits Have a read of this, written by bugjam1999: Volvo forum threadAlso have a look at my old volvo thread
Jan 31, 2024 23:01:21 GMT
Hiya,
As above, I wrote the guide mylittletony linked to - i turboswapped my 1988 back in 2015, before there was much in the way of online guides or help- I wrote the guide to help people avoid a lot of the frustrations I had.
Happy to talk you through it- as you’ve seen you’ll need a wiring loom which might be the most complicated part. The cost of having the car converted by a garage would probably be too much to make it a viable project, since £50ph would add up really quickly.
If you can borrow another car and take the 240 off the road for two weeks, then it’s not a difficult engine swap to do if you’re keen?
Happy to answer any questions you have. I’ve got a project thread here on retrorides that has a fair amount of detail.
Cheers
Hi. Thanks a lot . I will definitely contact you with the odd question here and there if you don’t mind ? Much appreciated.
