Nov 15, 2023 19:16:47 GMT
Hi, I keep seeing adverts for hydraulic operated scissor lifts that you drive onto and then lift up. Kind of like ramps but the platform under the wheels is flat on the ground and then you pump it up in the air. I’d like to buy a pair of them as they would suit low entry cars much better than ramps etc. Problem is, all of the adverts seem to be fake and I cannot find anywhere online that actually sells these things! Pic below is what I’m after. Anyone point me in the right direction?? Thanks
Hydraulic scissor liftbrachunky
@brachunky
Club Retro Rides Member 72
Nov 15, 2023 19:41:55 GMT
May be worth a look at Costco as they stocked a similar set a while back. You are right though, the web is full of fake sites advertising these.
at200
Nov 16, 2023 11:07:40 GMT
Last Edit: Nov 16, 2023 11:10:56 GMT by at200
Nov 17, 2023 19:47:05 GMT
Thanks for the replies!
Yes those CJ autos ones are what I’m after. Shame they are out of stock but I’m not far from them so might call in and have a chat with them. If I can get some then I’ll do a post on here to let people know what they’re like.
Hydraulic scissor liftChasR
@chasr
Club Retro Rides Member 170
May be worth a look at Costco as they stocked a similar set a while back. You are right though, the web is full of fake sites advertising these. Those were ones by Quikjack. I fancy a set myself. For what the OP wants, I think he wants the ramp type pictured, not the ones which lift via the sills.
Nov 19, 2023 14:10:51 GMT
I looked all over for several months for something like this as I needed to lift the van by the wheels. Didn't find anything and ended up with a set of these instead I don't drive up them but use a trolley jack and place the ramps under the wheels. Not ideal but gets the job done. I have thought about making the ramp part detachable but like so many ideas i doubt I'll ever have the time.
May be worth a look at Costco as they stocked a similar set a while back. You are right though, the web is full of fake sites advertising these. Those were ones by Quikjack. I fancy a set myself. For what the OP wants, I think he wants the ramp type pictured, not the ones which lift via the sills. Yes its the drive on type that I'd like. I've seen various similar ones that lift the car on the sills but it just doesn't feel right to me.
I looked all over for several months for something like this as I needed to lift the van by the wheels. Didn't find anything and ended up with a set of these instead I don't drive up them but use a trolley jack and place the ramps under the wheels. Not ideal but gets the job done. I have thought about making the ramp part detachable but like so many ideas i doubt I'll ever have the time. Those look pretty handy but just wondering what the low entry is like? Basically, I've got a beetle that it quite low so would catch on a normal ramp. Is there a reason why you don't want to drive up onto them?
Nov 20, 2023 17:15:17 GMT
I looked all over for several months for something like this as I needed to lift the van by the wheels. Didn't find anything and ended up with a set of these instead I don't drive up them but use a trolley jack and place the ramps under the wheels. Not ideal but gets the job done. I have thought about making the ramp part detachable but like so many ideas i doubt I'll ever have the time. Those look pretty handy but just wondering what the low entry is like? Basically, I've got a beetle that it quite low so would catch on a normal ramp. Is there a reason why you don't want to drive up onto them? The van doesn't drive at the moment, though even if it did i'm not sure it has the horse power. I've never liked ramps of any kind to be honest. If you like I can take some specific measurements to see if they suit.
Nov 21, 2023 10:28:58 GMT
Those look pretty handy but just wondering what the low entry is like? Basically, I've got a beetle that it quite low so would catch on a normal ramp. Is there a reason why you don't want to drive up onto them? The van doesn't drive at the moment, though even if it did i'm not sure it has the horse power. I've never liked ramps of any kind to be honest. If you like I can take some specific measurements to see if they suit. Haha fair enough Don't worry about measurements - the ones on the image give me a good idea
