There are certain brands which do nothing for you but somehow when the price is really good it's just silly not to buy one Now for some weeks I have been thinking about a cheap to run thing on wheels and this little 1.7 came into my life 110k miles and originally owned by Bridgend Council. It runs really well and with some tlc will make a decent van. Anyway, I'm off soon to meet a certain RR someone who despite chatting to for a few years have never met in person so laters........
I used to service these when I was an apprentice mechanic in 08, loved how nippy they were as a 17 Yr old. Bulletproof as well, we had several well over 200k on good servicing.
So today of courseโฆ. As you doโฆ.. I was speaking to brachunky on my way from Kent to beyond Glasgow. Turned out there were some wheels that were attached to his old Corsa pickup, that he managed to buy back from the new owner. So I did a mini detour into Ilkeston, and then onward 200 miles to Gretna to meet him and his wife to deliver them. Corsa. Wheels Scotland. Hand over. Good to meet you guys mate. Safely at Bills place now.
o after all these years of only phone calls & RR posts, Grizz & myself managed to meet up on his marathon road trip to Scotland at Gretna Green. Was really great meeting especially seeing as we both hail from the same city in SA! His original route before something changed it After telling him of my plans to fit some other wheels to the Astra which were about 270 miles from me, he did the Grizz thing and insisted on collecting them on my behalf adding another hour to his trip, what a gent! Said treasure tucked behind him It's been a great day indeed
Last Edit: Oct 8, 2023 19:42:25 GMT by brachunky
Easy enough and I met your awesome wifeโฆโฆ
She smelled lovely.
Such a girly girl.
Did a few jobs on this today like changing the worn out gear shift & handbrake gaiters as well as fitting the replacement 17" wheels. Obviously a harder ride with the 45 profile especially over the stone farm track but once on the open road it was pretty well behaved. Quite pleased. Have a few other jobs on it to do including: 1) No engine light, no limp mode, no speed limitations but it will not rev over 3250rpm in any gear so that needs looking into 2) Windscreen washers getting no water through to the jets or tubes leading to them. You can hear the pump working so would imagine its a blockage closer to the bottle
No messing around, straight to the important jobs.
Wheels.
Now we need someone to donate some kit to lower it all, a bit, for looks keeping functionality as a van
Well done on getting stuff done.
I donโt think it needs any lowering. Those wheels fill the arches nicely, and you just end up losing load carrying capability, or end up with a bone jarring ride.
No messing around, straight to the important jobs. Wheels. Now we need someone to donate some kit to lower it all, a bit, for looks keeping functionality as a van Well done on getting stuff done. I just had to fit them
Stop reading my mind Braap Looking through the Astro thread, I was imagining these flames with the Auto Distraction logo on the side!
Oct 14, 2023 18:24:21 GMT
Keep up with the cambelt intervals and they're a pretty solid engine.
Oct 15, 2023 13:47:44 GMT
I owned an Opel Kadett D 1.6 when I was young, rather borrowed from my parents, for me a reliable and immortal car. The only thing that was quickly replaced was the uncomfortable seats (I don't know if someone didn't have the same as me). It was a very solid car, which is hard to disagree with.
Last Edit: Jan 24, 2024 7:25:29 GMT by markfant
Oct 15, 2023 18:15:37 GMT
In the two weeks of ownership, its done 500 miles without missing a beat and has already earned it's keep taking tools etc down to Auto Distraction H/Q. Cleaned up the interior so is not a bad place to be & fixed the inoperative screen washer. I will need to replace at least a pair of tyre's at some point soon due to cracking sidewalls and do at least an oil & filter change for piece of mind. Actually become quite fond of it!
Oct 15, 2023 18:53:58 GMT
Tools are like thatโฆ.. you get used to them and they become comforting. Brilliant gift from brachunky for my collection. Including the year I was born. Thank you.
Oct 16, 2023 10:15:13 GMT
How long do you think you may be hanging on to this Astra-gnome.
Oct 16, 2023 11:15:09 GMT
How long do you think you may be hanging on to this Astra-gnome. Unless I discover big corrosion issues not yet discovered, indefinitely. Like many, I don't mind mechanical challenges but not chasing rust!
Oct 19, 2023 13:26:15 GMT
I may have mentioned that despite the Astra not being in an obvious limp mode apart from no going over 3200rpm, there was clearly something amiss. I pulled off the egr and associated pipework and found it to be incredibly restricted with soot/carbon and once cleaned out and refitted, I plugged the code reader in and cleared the ecu. Started it and was full of happiness as it revved through the range like a new motor. A few moments later, the sod was back to square one so clearly, the cleared muck was not the only issue. Read the codes again (1) and came back with PO105. Now the rest of the day was spent trying to remove a simple bolt which held the MAP sensor in position and this bolt happened to be of the round headed 4mm allen variety which had already been mullered by a previous owner. Must have tried nearly a dozen different ways to remove the bolt from what is not as an easily accessible area as one would think. In the end I managed to position a mini mini cutting disc on the end of a dremel and cut in a screwdriver slot, success at last! Anyhoo, waiting for a replacement MAP to see if that sorts the issue
Oct 19, 2023 16:08:25 GMT
And just like that the parts arrived MAP sensor and new air filter fitted. Not driven it yet but the revs shoot through the range like they should & no more codes so fingers crossed. I say fingers crossed as the sensor wasn't exactly expensive but we'll see!
Oct 23, 2023 21:11:22 GMT
Happy to say the above MAP sensor replacement & clean out has done the trick! Done 300 miles since and has been spot on.There's something to be said for low cost motoring especially when you actually enjoy driving the turd
