foxy99
Mar 14, 2018 20:21:45 GMT
So I have a pretty heavy old engine-hoist and would like to make it mobile as every time it needs moved a few miles I need to find helpers and a van. Plus the helpers get their clothes covered in grease lifting it. Was thinking of making a low-slung bogey with trailer suspension-units. The units are rated for weight they can support which got me wondering what the crane weighs. Thought the weight might have been printed on sticker but that's barely readable. I've tried Googling Epco for data but nothing and today found out it's probably made by Tangye... There is, what I assumed was, a 'go-faster' sticker above the data one which has a logo with word Tangye in it. Googling that tonight reveals they were linked to Epco for a while and did make jacks and other hydraulic stuff. pump on crane made by Epco so I assumed whole thing was but appears made by Tangyeinformation sticker not fully legible. above it is more modern-looking sticker with Tangye logomodel no. C10/20?made September 78 possibly
Last Edit: Mar 14, 2018 20:34:23 GMT by foxy99
slater
Club RR Member Number: 78
Mar 15, 2018 20:34:20 GMT
Hard to say without a picture showing the whole thing.
Mar 15, 2018 22:38:03 GMT
one last trip in a van to a weighbridge?
foxy99
Mar 15, 2018 23:25:12 GMT
That's what I was thinking strikey I actually have a trailer that could take it but would require a bit of manhandling to get it on. slater yeah I was thinking that might help. will drag it out lock-up at weekend and take picture
foxy99
Mar 20, 2018 15:14:15 GMT
Last Edit: Mar 20, 2018 15:23:16 GMT by foxy99
Mar 20, 2018 15:38:13 GMT
Hi, The model designations refer to their lifting capacities, at half and full boom. FYI - 1cwt is 112 pounds and 20cwt is 1 Ton. You're obviously a metric guy, where as I'm imperial. I know this doesn't help with telling you what weight it is but I would say it probably weighs about 150 to 200kgs. Colin Edited to remove exaggeration.
Last Edit: Mar 20, 2018 15:58:17 GMT by colnerov
Mar 20, 2018 15:45:02 GMT
Do you have some wood and some old house scales? Man maths is making me think it's going to be about 150kg lol
Last Edit: Mar 20, 2018 15:48:44 GMT by joem83
Mar 20, 2018 16:24:20 GMT
i reckon 200 kg max
What are the weight categories for the suspension units?
foxy99
Mar 20, 2018 18:32:39 GMT
Thanks for the responses guys The suspension units seem to come in 250kg, 500kg, 750kg and more so looks like smallish ones will be fine for me. I've actually bought the remains of a small trailer for £20 on Ebay. Pick it up Thursday. Plan is to take the units off that.
Mar 20, 2018 18:41:46 GMT
Mar 20, 2018 18:51:19 GMT
Hi, Modern cranes are built down to a price, older ones tended to be over engineered. Compare the sizes of component parts to see that it's likely to be heavier than modern ones.
Colin
foxy99
Mar 22, 2018 17:13:15 GMT
So I got my sacrificial trailer today - for £19.99, plus the petrol to go and pick it up. I only need the suspension units, wheels and mudguards off it really, and the hitch. However will probably use some of the frame to make new one. Slight problem is one of the mudguards fell off on way home. They were help on with self-tapping screws. The hitch on it just now is a piece of square tubing with a hole for a pin to go thru but the pin on my towbar was way too thick for the hole. I just bolted to to the towbar to get home. There is another drawbar/hitch with it that goes onto a ball. I reckon I'll use that. The suspension units are pretty small and I doubt I'll be able to ID them for a rating but I found out today that all that's inside them is rubber strips so there's not a lot that go wrong I guess. I think my test will be to see if they compress much when the weight of the crane is on them. If they look too strained I'll get new ones but that will probably mean new hubs and wheels too. Meantime I can use these to work out the design of the bogey. Basically I want it to be low but I can't just hang the crane from the suspension units so will need to design some sort of cradle under the units. sacrificial trailer. mudguard somewhere between Barrhead and East Kilbride nowgot this hitch and drawbar with the trailerwelding of the units to frame looks pretty well-doneI believe there is rubber inside the units. not sure why we have 4 screws as can't be opened due to welding
Last Edit: Mar 22, 2018 17:20:35 GMT by foxy99
Mar 22, 2018 17:44:04 GMT
bargain... I'd give the suspension units a good tappey-tap-tap to make sure they are solid all the way through , they can get a bit "delicate" from corrosion over time.
foxy99
Even if it's many years later I do like to bring a conclusion to any threads I've started. I'm in the middle of repainting this crane and it is going to end up in bits so I will be able to weigh the bits individually and then will now the weight of the whole thing. However I'd really need to change the title of the thread and I also have another one going on the refurbishment of the little green trailer (change of plans - not cutting it up) so it would make sense to start a new thread about the crane and just come back in here, soon, to post the weight A couple of pics may stir some interest to the other threads the trailer got a bit of attention last year cleaning crane back to bare metal for repainting
foxy99
well. I think I got my answer.... and it's a lot lighter than I imagined As touched on above I have the crane in bits while I'm painting it and replacing some bearings and bolts. So, today, I took my (glass) bathroom scales down to the barn hoping to weigh the bits before it goes back together. I expected it to not go well and just end up with broken scales but it went fine. I can't say the measurements are 100% accurate as I was helping balance the parts but they won't be far out. First part weight was the central post and its integral base which came in a shade under 5st Next was the boom and the tube that it's bolted to which slides down the central post. This was. strangely, the same weight. I then tried to weigh all the small bits and pieces including the front wheels and rear castors but by the time I'd got everything on the digital readout had timed-out so I did it again in 2 random smaller piles and they bath came in at around the same weight. Last for the day was the main base/legs and unfortunately the picture isn't showing the weight displayed but iirc it was 8st 10lbs I forgot to weigh the extension for the boom and didn't weigh the pump and ram as they are attached to each other with a hydraulic hose I don't want to disturb and they are kinda hard to handle Also forgot to weigh the steering tube/handle. So thus far I make it 18st 44lbs which is 21st 2lbs and you can mb add another 4 or 5 stone for the parts not weighed today. So basically it weighs about the same as a fat mate who you'd have no qualms about sitting in your passenger seat or riding along on the back of a tiny trailer centre post 4st 13lbsboom and vertical tube 4st 13lbswasn't quick enough to weigh all this togetherfront wheels plus bits n bobs 1st 4lbsrear castors plus hooks plus bolts 1st 3lbsbase was around 8st 10lbs
jpsmit
Last Edit: May 5, 2024 13:51:31 GMT by jpsmit
foxy99
Pretty cool but I don't think that one weighed 30st lol
