carmad
Nov 20, 2017 19:36:02 GMT
sorry for lack of pics
Fing photobucket !!!
but as some off you know i have a scimitar under my bedford ha van and i have alloys wheels but i would like steels
any one know off a set if they exist
scimjim
Club RR Member Number: 8
Nov 20, 2017 19:55:15 GMT
Standard steels were 14” and came with different trims over the years. Coupe and earlier Sabres came with 15” steels (only 4.5” though IIRC).
scimjim
Nov 20, 2017 19:58:31 GMT
Last Edit: Nov 20, 2017 20:00:28 GMT by scimjim
Nov 20, 2017 20:18:51 GMT
Hi, Triumph Stag steel wheels are 14" and the same PCD I can't remember if they are 5" or 5.5". If you want 15" then try Saab 99 or early Saab 900, 5" I think. Also Triumph TR6 can be had in 15" x 6", expensive though.
Colin
Dez
Club RR Member Number: 34
Nov 20, 2017 20:42:49 GMT
There's two types of 'scimitar steels', they'd both 14", 5.5" wide IIRC. The difference is in the centres, the earlier type doesn't have holes, the later does. The centre is also of a different design, so if you weld up the holes they still don't match.
Dez
Nov 20, 2017 20:48:01 GMT
scimjim
Nov 20, 2017 20:56:12 GMT
Not sure how your body shell sits but stag and modern wheels are the wrong offset for the Scimitar. TR6 look good though
Pid363!
Madness is all in the mind!
Jan 18, 2024 21:48:08 GMT
Stupid is as stupid does!
